Full throttle to Closed Throttle will cause most Engines to Stumble and Likely Die, UNLESS there is some sort of 'Slow Close' Function to prevent the Intake Vacuum from going Absurdly High during the Engine Deceleration.. The Carbed Engines had a DashPot device to allow the throttle to close Slowly.. That function has been taken over by the IAC Circuits in the ECU driven Engines.. I do not know which of the Three Idle Control Valves of the Z Motor have taken over that function.. so either it's the one you removed, or the Two that are remaining..
